AFE POWER AFE49-14017NM 2007.05-2010 DOWNPIPE-BACK STAINLESS STEEL DIRECT FIT EXHAUST SYSTEM - AFTER REAR TIRE
Features- Specifically engineered for diesel engines
- Fabricated from thick mandrel-bent stainless steel tubing
- 360-degree band clamps and factory-style flanges mean a complete seal
Specifications- Material: Stainless Steel
- Product Fit: Direct Fit
- Recommended Use: Performance Replacement
- Exit Location: After Rear Tire (Passenger Side)
- Main Piping Diameter: 4 in.
- System Type: Downpipe-Back
- Make: Chevrolet Gmc
- Year: 2007.05-2010
- Weight: 64 lbs
Price: 796.26
